09nytro
good point....pull engine and check bearings...better to do it now then having a hole in the side of the casesjaydaniels said:Just a word of caution, when these motors blow oil like this you end up with low oil pressure which in turn can very easily damage rod bearings. Just happened to a friends sled. Motor only lasted about 200 miles then self destructed. Do a search on my posts and you will see one explaining what happened and what to do to check for the damage,
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
That's exactly what happened to buddies. Hole right through the case. Completely destroyed the engine. Those motors are about 3000.00 used.
