MAJOR OVERHEATING PLAEASE HELP !!!
Grimm said:
Here is the kit # 8HA-124A0-00-00
This includes all necessary hardware required for the install, ie. exchanger, hoses, rivets, clamps, etc.
I scored mine for about $200 a couple of years ago, but I think it's a little more now. It pays to shop around...for some reason in Canada, it's actually cheaper than the States.
Grimm, I just want to confirm that this is the correct part for an 09 Nytro? I want to install a rear exchanger and want to be sure I order the correct part. Thanks in advance for your help.
I just purchased two MTX exchangers to a tune of $299.99 each. Ouch, that hurts.
I heard from a good source that they will be hard to come by soon as they are going to be included in the MPI 180hp trail turbo....glad I got mine
Something better for less coming soon.
If anyone is not running studs, take stud protectors off front exchanger and overheat problem is solved without spending more money.
Dan
Dan
I wish that were the case Ive had mine removed to two season. And the ice build up under there is terrible, over heats like always.
Hey Peter what ya got cooking?? Any hints? Any picks?
Roest i hope you make some fore us with McX turbos.
If Erik would change his turbo placement it would be a piece of cake. Right now the exhaust routing gets in the way.
A few pics. The short track version will be slightly shorter. Hardware and brackets pictured are just prototypes.
