Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Martens199 said:Ok so having a long lines runing all the way up to my dash wouldn't affect anything? So to get this right, I can tee into the line say from my boost gauge. Then from there to the controller(turbosmart) then back down the tunnel to the waste gate? What would I do with the fitting off the bottom of the turbo compressor?
One line from the "bottom" of the turbo to the boost controller, and the other line from the boost controller to the wastegate.
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
Ok yeah the lines are 3/16 of an inch ID. So I can run two lines all the way from the turbo up to the front and then back again?
Martens199
- Oct 1, 2012
Say if I was mounting the turbo smart valve up by the handle bars.
Martens199
- Oct 1, 2012
Do I got that right guys?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Yep. Thats right.
Martens199
- Oct 1, 2012
Ok thanks! Now that I have it installed I pressure tested and found that I have leaks on the turbo smart tee unless I turn it is fully closed then it doesn't leak. It comes from what looks like two little holes. Is this normal?
ghost rider
Suspended
- Nov 13, 2013
- Muskoka, Ontario, Canada
- Rxwarrior
- Muskoka , Ontario
TurboTime said:Turbosmart T
where did you mount the boost control lines lines…..from the turbo to the controller and back to the actuator or?
thanks
Barry
Martens199
- Oct 1, 2012
Yes from the turbo to the controller then to the actuator.
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
Martens199 said:Yes from the turbo to the controller then to the actuator.
How does the boost gauge read the new boost signal after it travels from the controller to the waste gate?
ghost rider
Suspended
- Nov 13, 2013
- Rxwarrior
- Muskoka , Ontario
Dimebag.....Seriously cool avatar .... It looks like it was shot in space. Well done!
