mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
We could only always get either the Speedo or GPS to show speed, not both at once because I think they have to use the same M400 input RS232 channel. I'd be interested to learn how to show / record both simultaneously.
kinger
Oh interesting, I see what you are saying, I hadn't thought of being able to compare to see 'actual' track spin. I wrote that as an 'instead' of the oem speedo just replace it with a GPS one so that at take off I can measure real acceleration in the data logs. I thought it would be fun to play with the stutter, or lower boost, higher boost, etc to see what yielded the fastest acceleration.
Looking at both and analyzing the 'slip' of track spin would be good information. Too bad we can't.
rat4020
- Oct 28, 2011
- Cold Spring Minnesota
- Polaris and Turboed Apex in a off road buggy
Mbarry are you running stock injectors
kinger
nope ID1000's
Vmax4creed
Copying this fuel system the design is pretty amazing if the Aux pump is mounted lower than the tank do you think i could get away from running the lift pump or it runs the risk of fuel starvation?
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
I have been running a single pump in the nose of my Apex with no lift pump for many years now. A lift pump would assist in providing higher flow at higher pressure for higher boost levels to compensate for a slightly undersized main pump, but my single fuel pump by itself is already pretty much matched to the turbo HP rating anyhow. I didn't want the additional amp draw or reliability issues of going over kill on the pump, learned from past mistakes...
