allyammies
If the sidewinder muffler is anything like the viper muffler watch them carefully I had two crack last year.
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
304 stainless will crack from vibration. Have a Corsa 304 stainless muffler on my
Duramax. After 10 years it's all busted up, that pipe has a ton of high frequency vibration at the outlet, surprised I don't have women trying to ride it...LOL...
**sj**
and the trail version will be baffled...baffled are not good for turbos
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 nytro rtx, 2005 RS Vector MTN turbo
was that the MBRP exhaust on your viper that cracked?If the sidewinder muffler is anything like the viper muffler watch them carefully I had two crack last year.
geez150
You are saying it will be metal baffles versus a glass pack? If so how do you know this?and the trail version will be baffled...baffled are good for turbos
allyammies
Yes it was.was that the MBRP exhaust on your viper that cracked?
budman 1000
- Jan 22, 2010
- Saskatchewan
that makes me a bit hesitant on buying one if they tend to crack, I know the Sidewinder is mounted a lot different than a viper, but with your info and your experience on the viper I think I'll wait and see how they stand up before I buy one.Yes it was.
I'm going to put on the TD Turbo Force 2.5" exhaust on my Sidewinder
geez150
Well baffles can't be bad for turbos or the factory wouldn't use them. SJ When you say bad I'm assuming you mean bad for performance, not bad as in it will melt down the motor?
**sj**
Yes sir... correct... less performance.... their race is straight through perf pipe.. who knows... trail might end up that way... time will tell.... many great choices out here now though...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Think I saw that for anti-lag you dont want a hard baffled muffler. I assume too much heat not getting out. Where as the "glasspack" type baffled muffs are more or less straight thru to let the flames out without turning everything cherry red inside.
Blue_Blood
- Nov 3, 2015
- sarnia
- 2010 yamaha apex ltx gt
I've looked at ggp mountain and it says 4 to 6 db louder at idle and 10 to 18 db full throttle curious if anyone has one seems like no one makes a trail version for the sidewinder
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Here's my ggb sound clip for you!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Is the GGB 2.5" in and out?
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
The muffler core is 2.25. Inlet and outlet on the muffler are 2.5.
I'm actually curious to see some of these mufflers on a dyno comparison. Its such a short exhaust run compared to the 1100 turbos, I wonder how much the size actually matters.
DMCTurbo
- Nov 12, 2005
Are you still running the GGB exhaust?The muffler core is 2.25. Inlet and outlet on the muffler are 2.5.
- 14K
