Tyloooor
pm me that setup too....please and thanks
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Shadow 44's post with Turk's black spring set up...
http://www.ty4stroke.com/threads/turks-nytro-drag-n-fly-clutching-with-black-spring.116830/
mnman309
I heard there is a search function..... !
I should use it once in awhile!!! thank you
I should use it once in awhile!!! thank youupei93
- Apr 27, 2008
- Dalhousie, NB
It actually doesn't work that well (poor Turk is probably swearing at me from up above right now lol)...I have better luck searching in Google.I heard there is a search function..... !I should use it once in awhile!!! thank you
shadow44
try thisShadow 44's post with Turk's black spring set up...
1 bolt 3 washers in arm
1 bolt in od
1 bolt 1 washer in tip
centre empty
run black hc spring
With this set up I was hitting around 9050 rpms around 1000ft...engagement was about 3800 rpm....leave the secondary stock. My sled ran best with this set up...I walked a lot of sleds with this clutch set up and my bolt ons.
