The T is the trail can. It's quieter than the other one and makes a bit less power.
Thanks!
No need to play the hp game, and I'm not looking to start that debate, I can say tho that the first dyno run of a box stock viper and a box stock 7000 both with zero miles was 127hp..maybe that's the number people are referring to, after several runs on the dyno and getting the engine loosened but they both made 134. In another point of view, (I'm simply using this example because I know the number and the dyno sheet is posted online) D&D barker can alone made 142hp..is it safe to that it gained 15hp from stock? Absolutely not, can't go by the first number that came off the dyno, in five dyno runs the engine freed up 7 more hp simply by getting broke in. In the case of that exhaust, it had a 10hp increase at some area of the rpm range and a 7-8hp increase at peak hp where it really matters
More important than the numbers is the change and where it occurs. A dyno has the ability to plot out TQ versus RPM showing you the area under the curve. Now I know a CVT doesn't really run there, but it's still meaningful data.
I find it interesting how little HP and TQ the Viper really has. It definitely punches above it's weight compared to other sleds.
Check your TQ figure. The way I see it we'd need about 74 ft lb to make 125 HP at 8700.As Cannondale mentioned....my sled makes more power above 9,000 than it does at 8,800. I tried clutching this thing according to dyno numbers and it lost time and performance.
With that said.....I was corrected by many when I told people the Viper was making 130-135 hpr. It only makes 127-129 AND only 52 ft. lbs. of torque.
