spray25
Are you running race fuel?
BLACK RX1
- Feb 11, 2004
- south central b.c. canada
- www.kencom.ca
at this time we were running 94 techron but we will be switching back to 91 as we have 3 headgaskets.
spray25
Definately looks lean then. Check, recheck, and then check again for leaks. I wouldn't be in a hurry to jet uo yet. It won't do any good if you have a leak.
Skydog
Hard to say you need more time on the plugs, how much time you have one them?
Skydog
Skydog
BLACK RX1
- Feb 11, 2004
- www.kencom.ca
theres a maximum of 10-15 minutes on those plugs.
black rx1
black rx1
Skydog
Yea you need more time on them to read them.
I dont think your sled is getting enuff fuel, fuel pump, fuel pump reg. what is your fuel psi?
Skydog
Is it making any boost??
BLACK RX1
- Feb 11, 2004
- www.kencom.ca
hey guys thanks for all your help, we did some tuning and got her all cleared up. it still hits the rev limiter but we knew this as we dont have our clutching parts. by the way what are you guys using for clutching?
black rx1
black rx1
Skydog
What was it???????
spray25
Yeah what was it?
Freak
when they dont tell you its usually embarrassing. Maybe he forgot one of the plug wires...
rx-hi
or maybe crossed lines to intercooler the bov and the fuel regulatot
BLACK RX1
- Feb 11, 2004
- www.kencom.ca
ya it was a little embarasing
we crossed the lines on the intercooler that goes to the carb t's and fuel pressure regulator
. we got confused because we figured the bigger line should go to the bigger outlet and the smaller hose should go to the smaller outlet. iguess thats what you get for working so late on it the night before. oh well at least its running strong now even after that little mistake.
thanks for all your guys help
black rx1
black rx1
spray25
Hey at least it was something easy to fix.
rx-hi
At least it was an easy fix. I did not do that but in looking for the leak in the t"s Mc-x said crossing lines could cause, sorry I did not mention sooner. Are you running a mountain or flat land? Best thing is you do not have to take off the carbs to change those lines. Did I say I hate taking the carbs off? I hate taking the carbs off?
