DooAssassin
I checked alingment today, it is dead on. Perhaps you are right about the belt sliding threw the seciondary too fast and cuasing excessive heat. I tightened it to 3-9 and its a black white strip. I will let you know what happens. Thanks everyone
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
would help to have helix angle there might be the problem
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
DooAssassin said:I tightened it to 3-9 and its a black white strip. I will let you know what happens
Not a good idea, Yamaha white should not be tighten that much, it will bind before clutches are fully shifted out.
You should put an EPI purple or an Arctic green spring in there, with much more sidepressure that grips the belt!
DooAssassin
I have a white secondary spring that came with the sled. Its white with a baby blue spray paint stripe. its 3/4 in taller. It feels alittle harder compression and less windings. does anyone know whats its from? Im sure its a aftermarket spring for a 03 rx turbo.... I have a white spring primary also and a rx1 o3 turbo helix.
Triplerev
Sorry to ask again....from a stop, if you pin the throttle for say a 10 second run wide open...what does the rpm do from start to finish.
DooAssassin
engages now @ 3800 revs to 10500 , then floats from 10100 to 10500 depending on terrain. BTW this is after installing a tigher seciondary spring and adding 2 washers to the tips of the weights.
Only thing is off the trail it goes to 10500 and dives to 9800 and stays there during acceleration.
DooAssassin
Solved, Thanks to your help. It was not enough secondary side pressure.
Jason
Jason
