Coaster89
- Dec 1, 2013
Hi, Im going to boosting my vector 2006 with a custombuilt turbo system with 16t.
Going to change the chain tensioner into the blue ones.
Installed a Mcx Headshim on the Engine last weekend, grind the camgears as in the manual.
But I'm worried that I've done wrong, the engine line up well both on the crank and the cams..
I will show you guys pictures of the camtiming I've done, i grinding the sprockets about 1mm with dremmel like the mcx manual described.
So I have turned camgears where the arrows are pointing to get the timing correct.
Can anyone tell me if this is right or wrong?
Sorry for bad English, I'm swedish
A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Yamaha Viper MTX 162" MCX Turbo 190
- Sundsvall
Looks good to me!
I hope the arrows are pointing away from the chain tensioner?
A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Sundsvall
Here's a picture of my gears (nytro)
https://www.dropbox.com/s/9fej7303ei39x ... .26.39.jpg
I grinded the left side.
Coaster89
- Dec 1, 2013
On both gears I think?
I Hope my settings would be fine then
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
If you have the #1 cylinder on the TDC - top dead center, the flywheel markers aligned, and the dots on the cams aligned (sort of as You have ground the holes) You're good to go.
Have you rotated the engine a couple of revolutions to make sure nothing is binding?
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
rxrider said:If you have the #1 cylinder on the TDC - top dead center, the flywheel markers aligned, and the dots on the cams aligned (sort of as You have ground the holes) You're good to go.
X2 Make sure to check the dots on cams are aligned with #1 @ TDC!!! Don't take any chances if you are unsure, feel free to ask questions....
Coaster89
- Dec 1, 2013
Yes. The #1 are nearest the camchain? I didnt turn the engifte over after i get off the head.
But now I turned the engine over à couple of times and all seems to be good.
- 6K
