Measuring clutch shaft paralellism?
Soupy
Age
50
West Michigan
2017 Sidewinder LTX-LE
Wondering if parallelism is my problem. Other straightedge measurements say yes.
Is this an accepted way to measure it? Bushings, gauge fixturing and engine are tight.
This what you need
STM Horizontal Engine Alignment Tool
What does the belt look like before it goes and when it goes does it go in pieces are snap in half? What speed or circumstances..
Are your clutches completely stock?
Have you added any power?
Do you ride off trail in deeper?
I seriously doubt lack of parallelism... And you'd have a insurmountable issue if it was...
Pieces
Hot clutches
Problems with both stock clutches and with tuning bits added
No added power
Both on and off trail
I understand but I believe that i have the means to check it so I figured I would
Belt height usually as high as possible without creep or squealing, I learned this could be too tight
8jp
I've been thinking about the same thing. For those blowing belts, are the clutches parallel? Offset is only 1 of the measurements to worry about.....
My clutches where always bang on and still blowing belts. Until I changed the belt and helix.
Also like mentioned before you don't want the belt too high in the clutch. Flush
Pieces
Hot clutches
No added power
8jp
Don’t go any tighter than top of sheaves. Especially with gates carbon.
beat me to it...too high of belt...longer and lower belt easier on belt..
replace secondary spring, too weak....dry cycle secondary to verify no casting flash hang up with sec sheaves...verify clutch rollers are not flat spotted...
seal belly pan with silicone (extremely important if off trail)........run stock gears or lower...
dry cycle primary to verify smooth moveable on pin movement....verify slider puck condition...replace primary spring ...
look on underside of clutch guard for witness (skid) marks from belt...
