Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Wondering if parallelism is my problem. Other straightedge measurements say yes.
Is this an accepted way to measure it? Bushings, gauge fixturing and engine are tight.
SuperTurbo
**sj**
What does the belt look like before it goes and when it goes does it go in pieces are snap in half? What speed or circumstances..
Are your clutches completely stock?
Have you added any power?
Do you ride off trail in deeper?
I seriously doubt lack of parallelism... And you'd have a insurmountable issue if it was...
**sj**
Also where do you set your belt height at... And 8jp belt?
Soupy
- Jan 10, 2017
- West Michigan
PiecesWhat does the belt look like before it goes and when it goes does it go in pieces are snap in half? What speed or circumstances..
Hot clutches
Problems with both stock clutches and with tuning bits added
No added power
Both on and off trail
I understand but I believe that i have the means to check it so I figured I would
Belt height usually as high as possible without creep or squealing, I learned this could be too tight
8jp
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Ultimax! I'm telling ya
Soupy
- Jan 10, 2017
- West Michigan
It's on my to do listUltimax! I'm telling ya
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
I've been thinking about the same thing. For those blowing belts, are the clutches parallel? Offset is only 1 of the measurements to worry about.....
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
My clutches where always bang on and still blowing belts. Until I changed the belt and helix.
Also like mentioned before you don't want the belt too high in the clutch. Flush
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Pieces
Hot clutches
No added power
8jp
Don’t go any tighter than top of sheaves. Especially with gates carbon.
Soupy
- Jan 10, 2017
- West Michigan
Thanks fellas
**sj**
beat me to it...too high of belt...longer and lower belt easier on belt..
replace secondary spring, too weak....dry cycle secondary to verify no casting flash hang up with sec sheaves...verify clutch rollers are not flat spotted...
seal belly pan with silicone (extremely important if off trail)........run stock gears or lower...
dry cycle primary to verify smooth moveable on pin movement....verify slider puck condition...replace primary spring ...
look on underside of clutch guard for witness (skid) marks from belt...
