MadMax
I put mib in our sleds on our last ride of the year........... Put on about 50 miles. Had them still in the trailer since coming back about 6 weeks ago.. I went down to start them up to change oil/filter expecting to spin the starter a lot because of sitting that long... "BUT" to my surprise BOOM it started before I could remove my thumb from the button.. And they both ran great... Hmmmmmmmmmmmmmmmmm.. Here's hoping. MM.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Blue Dave said:Indy said:you guys should check out what I did in my (is this a scam) thread.
Some of the "Sea Foam" guys already thought that is what this thread was! LOL!
You mean its not!!!! Well darn you fooled me!
Here I put in my sea foam and left the sled sit for a year and it started right up and ran awesome on my 50 mile ride.
Indy
Sled Dog said:Well all three of my carbureted sleds are treated each with one bottle of MIAB with the tanks full of premium / regular gas mix ran the sleds quite a bit to make sure it is in the carbs. They will be started once a month throughout the summer. Each sled has about 1 or 2 gallons of regular and topped off with MIAB and premium. We will see next fall how this stuff does. On a different note I had my generator sitting for a least a year with regular fuel filled it up with fresh fuel and it was running rough. I poured about 2 ounces of MIAB in the gas tank and shook it to mix and let it idle then full load then let it sit for about 4 hours then tried it again sputtered around for a bit then cleaned right up and has been purring since. We will see this fall how the sleds make out.
Great review Dog and Max. I just started my edger, leaf blower, sitting since November with 87 gas & MIB, first pull on both of them.
12 pages cannot wait until fall
Well there must be something to this MIAB my sleds have never started so good sitting in the summer like this. I mean they are starting right now no hesitation and running smooth and with seafoam they sure never started this quick. Let them idle till the left side running board is hot and shut them down for a month.
dexter
What are u guys using? Shock treat or ethanol preventative? Just curious what your methods are for summarizing.
I used the Mechanic in a bottle product one bottle for each sled. Filled the fuel tank right up with premium and starting till hot once a month.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I have started using it as well got about 2 years now and everything starts as it should and no gummy carbs or issues. Pretty good stuff!
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
THANKS GUYS!!!!!!!!!!!!!!!!! glad you like it!!! MIB rocks!!!
- 8K
