RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
if you want to get a good fuel system cleaning dump the whole bottle in if your tank is holding 7-10gal of fuel.. slosh it around a bit best you can and then run the sled for 5-10 min to get the MIB into the entire system.. till its warmed up and then let it sit for 24hrs or longer its not going hurt anything if it sits for a longer period of time or even a year or 2.. but when you start it,let it warm up as usual and ride it so all the little nasties can get sucked thru and burned up.. DO NOT just let it sit and idle and then shut it off.. the little nasties can get sucked up and then just sit in your carb or injector without the suction that being on the throttle would give you.. does that make sense??? kinda hard to explain.. i think that might have been what happened to indy with that piece of debris that got stuck on his needle.. you just want to be able to suck all the crud thru and burn it up in normal riding conditions.. hope you like it and please report back Dog!!!
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Indy said:yes, while towing my sleds last weekend. My milage increased from the usual 8 mpg while towing to 12.8.
dump some in that sled!!!!!
Indy
11 pages! WOOHOO
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
RIGIDONE said:Indy said:UPDATE:
good to hear indy!!! get a chance to try the EE yet????![]()
Whats EE ???
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
another B3C product called Engine Energy..EE for short..
Indy
RIGIDONE said:Indy said:yes, while towing my sleds last weekend. My milage increased from the usual 8 mpg while towing to 12.8.
sleds are put up and ready for summer, unless we get enough snow to ride (unlikley).
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Indy said:RIGIDONE said:Indy said:yes, while towing my sleds last weekend. My milage increased from the usual 8 mpg while towing to 12.8.
sleds are put up and ready for summer, unless we get enough snow to ride (unlikley).![]()
yea..u totally need to road trip out here!!! we are just getting started!!! i know i am like 4hrs away from youngstown ohio..and we usually can ride well into march,.. except for last year.. i got a couch and an extra phazer if u ever feel up to it..
Indy
last time I rode in NY it cost me a skid. thats when I purchased and had installed a M10
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
RIGIDONE said:another B3C product called Engine Energy..EE for short..
I dare someone to start another thread on the EE!
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
LOL!!!!!!!!!!!!!!!!!!!!!
Indy
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Go ahead Indy. I double dog dare you!
Indy
you guys should check out what I did in my (is this a scam) thread.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Indy said:you guys should check out what I did in my (is this a scam) thread.
Some of the "Sea Foam" guys already thought that is what this thread was! LOL!
Well all three of my carbureted sleds are treated each with one bottle of MIAB with the tanks full of premium / regular gas mix ran the sleds quite a bit to make sure it is in the carbs. They will be started once a month throughout the summer. Each sled has about 1 or 2 gallons of regular and topped off with MIAB and premium. We will see next fall how this stuff does. On a different note I had my generator sitting for a least a year with regular fuel filled it up with fresh fuel and it was running rough. I poured about 2 ounces of MIAB in the gas tank and shook it to mix and let it idle then full load then let it sit for about 4 hours then tried it again sputtered around for a bit then cleaned right up and has been purring since. We will see this fall how the sleds make out.
- 9K
