I closed the rear tunnell on my 07 phazer and mounted the phazer side saddle bags on the side. This past weekend rode 400 miles in the UP, Temp was 28 to 31 degrees, The fenders got hot enough to melt and drip onto the tunnell. The bags end up laying against the fenders. I was going to try and make some aluminum braces to go up off the tunnell to create an air gap, Any other Ideas???? This happened last year too but I was riding in 45 degree weather. I always wrap my clothes in plastic bags so they don't get wet, the plastic bags got hot enough on the inside to melt the bags to my clothes
boy did that suck. Ruined my clothes. This time I put a whole newspaper on the inside of the bags which provided enough insulation not to melt the plastic bags.
boy did that suck. Ruined my clothes. This time I put a whole newspaper on the inside of the bags which provided enough insulation not to melt the plastic bags.kodak
rode 30 miles this weekend with bag on tunnel no turn on exhaust no burn then 15 minutes flat out in powder burnt side out of bag lost change of clothes
snofreak500
what you could do is bend sheet metal that bolts on the same spots as the fenders and is similar to the fenders. Leave an air gap so the metal takes the heat and this will sheild the fenders from the heat and give you some support...
Ruckus
Are you using the Yamaha heat shield?
snofreak500
the yamaha heat shielding only covers the area between the seat and exhaust the fenders are pressed closer to exhaust due to saddle bags and cause melting. I found that some of Skinz heat mesh tape type stuff on the inside of my fenders kept mine from melting during breif contact with the muffler this tape may also help you with heat reflectieveness...
snofreak500
at least i think from what i've seen.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
The factory tunnel closure kit has an aluminum piece that prevents that.
Ruckus
snofreak500 said:the yamaha heat shielding only covers the area between the seat and exhaust the fenders are pressed closer to exhaust due to saddle bags and cause melting. I found that some of Skinz heat mesh tape type stuff on the inside of my fenders kept mine from melting during breif contact with the muffler this tape may also help you with heat reflectieveness...
The heat shielding I got with my kit is much more extensive than that. It covers both side panels (fenders?) all the way down and creates air space for cooling. That is why I bought the proper kit rather than slap a piece of aluminum over the hole.
Does anyone have a picture of the heat shielding that comes with the yamaha kit?? thanks
Here you go.The kit is worth it.
http://www.ty4stroke.com/viewtopic.php?t=64225
Ultrafrozen
- Feb 14, 2010
- Ontario, Canada
- Yamaha SR Viper
cannondale27 said:Here you go.The kit is worth it.
Yup, worth it. The two "ears" on the part to the left protect the rear fenders well.
GT03235
I have the yam saddle bags and have been fitted since new and i fitted a tunnel block off and have never melted anything!
greenthumb
When I closed the of the tunnel I noticed the plastic became quite soft and warm enough you could smell it at times. The local auto parts guy stocked and recommended this stuff;
http://www.designengineering.com/category/catalog/dei-cycle/insulating-materials/cool-tape
I covered the inside of the plastic with a single layer. Took about 2/3 of the small roll.
It worked very well. The the plastic is cool to the touch now and the adhesive seems to hold up well.
Everyone thank you for your input, it continues to amaze me at the wealth of information and help this site provides!!!!!!!!!!
There is so many great post and info I have picked up over the years!!
There is so many great post and info I have picked up over the years!!Similar threads
- 16K
- 7K
