Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
I installed my filters, exhaust, and fuel controller on Saturday, and when I pin the throttle from a dead stop to maybe 1/8th throttle or so, my sled misses once or twice. Is this a lean condition causing this? Once my RPM's are up, it goes away and pulls really good. I switch my gauge over to tach mode, and I don't think it's hitting the rev limiter, cause the tach only gets to 8900-9000 RPM's. I don't know if the map needs to be tweaked slightly or what? If anyone could let me know if this is normal or not, I would appreciate it. Im not too familiar with modding a 4-stroke.
Thats a typical Nytro... all noise but you dont feel it in the machine, right??
yox185
MrSled said:Thats a typical Nytro... all noise but you dont feel it in the machine, right??
X2 You also notice more with the new exhaust.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Its the exhaust, im guessing. No worries tho
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
It doesn't seem like I notice a lag in acceleration when it's doing it. I would need to get on a hard pack trail and try it though. Snow conditions today aren't exactly ideal for traction.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Bahr i sent u a pm
07Nytro
- Dec 8, 2007
- Winnipeg, Mb
- None right now
my friends apex did that after he installed a hauck exhaust
00-NUKE
07Nytro said:my friends apex did that after he installed a hauck exhaust
I have the full hindle set up and it does the same thing. If you're getting multiple studders, it may be the rev limiter if not clutched for the added power. Mine has a single hesitation due to the lack of exhaust back pressure. That's normal.
YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
I know mine does that. But like Mr. Sled said I don't notice any loss in engine performance while it pops
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
I have a clutch kit that i have to install yet. I dont have the right secondary spring, so i didnt bother putting any of the kit in.
Zakre
Bahr05 said:I have a clutch kit that i have to install yet. I dont have the right secondary spring, so i didnt bother putting any of the kit in.
My ulmer clutch kit for the xtx uses the stock secondary spring, what spring are you going to use?
polish hammer
my 09 xtx had a split second hesitation when you would punch it ,called ulmer he said to tighten up throttle cable some, have not had snow vet to test.I have header filters clutch kit stock can. hard to believe that would help will see
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
Zakre said:Bahr05 said:I have a clutch kit that i have to install yet. I dont have the right secondary spring, so i didnt bother putting any of the kit in.
I am going to use the stock spring, but I have to buy it first. My sled had a Hauck clutch kit in it, and the secondary has a silver spring in it now. I have for a sale a Hauck clutch kit. I don't know much about it, but if someone asks questions about it, I will try to find out and let you know!!
saskattakman
my 09 xtx does the same thing afr goes way up to 16.1 then comes back im getting about 3 pops but it still pulls like crazy. any way to get rid of this?
Get rid of the system that injects air into the system to make the sled not have as much engine braking and allows it to feel more like a 2 stroke.
