Mod results 06 RTX
ROCKERDAN said:
mrance111 said:
With the Excell if you get the side panels painted as I did, it looks stock. Several people thought my Excell was the stock exhaust.
that excell does look nice.....what is the best cost on these????....what is that rumble pack cost and does anyone have a pic of one?
thanks for the PIC RESIZE BUD!!!!.....fits much better!
Dan
Dan, The Excell is about $750 and the custom paint was about $250. But I had to purchase the paint form Color Rite and I needed 2 colors. The base Silver Metallic and the Deep Red Metallic which were $75 each for 1/2 pint and then $100 to get it painted. So I have $1000 into the exhaust. But let me tell you that everyone comments on the look and sound. I get Doo, Cat and Poo guys constantly coming up to me to tell me how awesome the exhaust looks and sled sounds. I had 2 Apex owners checking my sled out last weekend. Pictures don't do the Excell justice.
How does one see if you see what has been loaded onto the pc3/ign module?
Do you mean how do you know what map has been loaded into them.
Dan
I bought a used one on here for 450.00 and it had 270 miles on it. PM sj, I believe he will be ebaying his soon if he did not already.
with the bikes we hook a laptop to the powercommander,and load maps with PC3 software....
i assume you can pull up maps and tweak them within the software on your laptop correct???
Dan
Srxspec said:
Two ways to store maps. With a Multi-Function Hub and a Handlebar Switch which retails for $160 this will allow you to toggle between 2 maps. Next you can get a LCD Screen in which you can load an infinite amount of maps in (most I have tried is 8 maps at once) that is stored on a memory card which retails for $300. The LCD screen also allows you to datalog.
Is this a LCD screen mounted on the sled. Kinda like a GPS on a ram mount? If so, arn't LCD's freezeable? Brand,info?
FXR has the LCD setup...maybe he will chime in here later....here is what he wrote on page 2....
FXR said:
hey rocker dan i,m on the lake of bays. i was one of the guys that tried to get to mary lake last year at the end of the season for some radar running but conditions were to bad. anyways i,ve got ulmer,s set up air box mod, pc controller,ignition module and lcd display. coudn,t ask for a better set up. i,v got four maps programmed stock,fuel mileage, hi-performance and nitrous. any questions you,ve got p.m me. i haven,t had a chance for any radar runs you know how our conditions have been. fxr
he has his velcroed to the handlebar pad...not sure about the cold,but I assume it must work ok.
Dan
Dan
Yes....
sceen
my set-up is from ulmer racing. including the lcd creen which is also by dyno-jet. i never take the lcd off the sled and so far no problems with the cold. if your worried about theft. just unclip it and take inside with you.
How much louder is the Excell than the stock exhaust?
I got some great install pics...looks really straight forward and easy...Ill post them up along with any other things that come up when i do mine next week....i dont think ill have it though till tuesday if Im lucky....gonna be a long week!
here are just a few of the install pics,for anyone wondering what they look like...they install right on left side to the light bracket,near the main harness plugin.
Dan
Dan,
It shows the PCIII mounted upside down. That’s fine but when you add the ignition module the connector is located on the bottom because the PCIII is mounted upside down. I mounted my PCIII right side up and the ignition module connected much better. JMO.
mrance111 said:
Dan,
ok great,thanks for this info.....as we all know sometimes the install directions arent the best,and we find better ways to install.....
so you mount both boxes right side up????
i just got my tracking number,and should have them in my hand by monday!!!....
Dan
Have any of you guys done any head work to your motors?Just curious all this talk about adding fuel and exhaust but no mention of head work.Thanx
The LCD is made by Dynojet for the Dynojet items. I have run it down to -40*F last season with no freezing problems. I had one on for 400 miles last weekend and every morning it had frost on it, but functioned just fine.
