70superbee
Got a question about shock removal, Have the bolts out on each end and do I take the RA off the side of the tunnel or does it just unplug at the shock.Already set the RA too full hard. Don"t want to break anything. I went in the tech pages it shows suspension removal.
Thanks for any help.
Richie R
Richie R
apex yooper
Unscrew cable from shock. Set on full hard before removing.
70superbee
Hey thanks I guess I did not move the rubber boot far enough up to see it.
Richie R
Richie R
SledFreak
- Feb 7, 2005
- Ontario. Canada
What about a GT, I have the same question. Where do I un-hook it at the shock or do I un-hook it beside the chain case? Do I remove the suspension bolts first, then un-hook it. I can't seem to get my hand up beside the shock to un-hook the wire with the suspension bolts in. Any help?
apex yooper
shock
Drop the back of suspension, then you can get your hand in there better.
stinx
I just did this on my attak. having a floor jack and
stand makes the job very easy. I just reinstalled my shock this A.M. after a respring/revalve. I was able to do it myself easily.
apex yooper
shock
Just a tip. I use a chain fall, and floor jack. I absolutely could not align the rear suspension holes until I unbolted the limiter strap. I thought disconnecting the transfer rod would do it, but it didn't help.
rosco
Re: shock
I had the oposite experience with mine. I found I couldn't line up the rear holes until I pulled the back bolt out of the transfer rod. Then it was simple to line up.
As far as the wire on the GT I disconnected it behind the chain case and pulled it through. That way I didn't have to cut all the cable ties off that hold the wire to the front arm.
apex yooper said:Just a tip. I use a chain fall, and floor jack. I absolutely could not align the rear suspension holes until I unbolted the limiter strap. I thought disconnecting the transfer rod would do it, but it didn't help.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Re: shock
That's what I was thinking. Disconnecting it from behind the chain case. Was it hard to feed the wire back through after?
rosco said:apex yooper said:Just a tip. I use a chain fall, and floor jack. I absolutely could not align the rear suspension holes until I unbolted the limiter strap. I thought disconnecting the transfer rod would do it, but it didn't help.
rosco
It was a litle finiky fishing it up behind the chain case but not anything to worry about.
LJ 452
To replace the rear skid bolts on the Apex what you need to do is get the front in, then remove a bolt from the transfer rod (I ussually do the rear bolt) then raise the rear of the sled slowly until everything lines up. No need to compress the susp. or anything. At least thats how it works for me.
Warp
I just removed my mono shock and when I went to disconnect the cable from the shock by pulling back the rubber the cable let go.I'm sending the shock for re valve tomorrow.What do I need to do with the cable?Do I need to buy a new cable or can I use the old one?The tread on the old one don't look damage.
- 149K
