vice108
I had my RTX up on a stand last night and noticed that some of the welds on the monoshock are starting to show a little rust. I remember reading about frequent rusting on the 05s last year. Is there anything that I can do about it or is it just the way it is? Would it help to put some of that "rust eater" on any spots and then cover them with touch-up paint? Any advice or tips apreciated.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
When I put my sled up and melt everything out of the suspesion I spray down the whole skid with WD-40
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
MightyWarrior said:When I put my sled up and melt everything out of the suspesion I spray down the whole skid with WD-40![]()
Same here, Also I use a degreaser to wipe off some of the xtra grease that always seem to get everywhere. No rust on the RTX yet, and none on my 02 viper
JERSEYJOE
RUST ON THE MONO SHOCK
I noticed the same thing when I changed my spring. It almost looks like the weld is failing and the resulting bare metal is rusting. Hope these suspensions dont suffer the same problem with breakage as the old Pro Action " W " arms did.
FWIW, I keep an aerosol can of 3M Rustfighter 1 on the shelf. It's a clearish amber colored waxy interior panel coating/rust proofing spray. Not cheap, but works great for all kinds of things. It can be easily cleaned off with solvents. Eventually, it may wear off if in a direct constant spray, but it is pretty resilient overall if it's left to tack up. It also stays very well in little weld seams and such...
YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
vice108 said:I had my RTX up on a stand last night and noticed that some of the welds on the monoshock are starting to show a little rust. I remember reading about frequent rusting on the 05s last year. Is there anything that I can do about it or is it just the way it is? Would it help to put some of that "rust eater" on any spots and then cover them with touch-up paint? Any advice or tips apreciated.
I am going to paint my suspension later this summer with POR15. It will never chip or rust again. This stuff is awesome and comes in different colors.
http://www.por15.com/
-Moose
dirkdiggler
Suspended
YammiMoose said:vice108 said:I had my RTX up on a stand last night and noticed that some of the welds on the monoshock are starting to show a little rust. I remember reading about frequent rusting on the 05s last year. Is there anything that I can do about it or is it just the way it is? Would it help to put some of that "rust eater" on any spots and then cover them with touch-up paint? Any advice or tips apreciated.
-Moose
I'm going to take my sled completely apart this spring. I'm going to have the zerts properly welded. them I'm going to have hte skid powder coated. I'll never have to worry about rust again!!!
vice108
Anyone have an answer as to what, if anything, I can do about the rust that is forming now?
YammiMoose
- Mar 18, 2004
That would be a quick fix. "rust eater" Don't use WD40, it is oil and water that easily goes away. ZEP is 1 millions times better.
ultimatewarrior
Rather than using WD-40, which will not last, your Yamaha dealer should carry a spray-oil that was first developed by Boeing for use on aircraft (I can't remember the name). It leaves an oil film and provides excellent protection. I sprayed my entire skid and A-arms early in the year.
ultimatewarrior
I just called the dealer - it is under the Yamaha name and is called "Boeshield T-9." I doubt you will find anything that works better.
vice108
ultimatewarrior said:I just called the dealer - it is under the Yamaha name and is called "Boeshield T-9." I doubt you will find anything that works better.
That looks like a good product and thay carry it at my dealer. Thanks for the tip.
