Bob Quale
- Jan 26, 2005
jmahler,
What dealer in CT has the sleds to look at!!!!!!
Thanks Bob
Thanks Bob
YammiMoose
New England Cycle in Hartford.
Great guys over there. They also help support the local Grass Drags.
-J
-J
Bob Quale
- Jan 26, 2005
jmahler
I have gone to Conn power sport in the past and been very hapy. How do the guys in Hartford compare price wise?
Also, I see you ordered a GT. Why the GT over the Attack?
I have allways riden a short track my self, but there has been a lot of positive talk about the Attack.
Thanks Bob
Thanks Bob
SledFreak
- Feb 7, 2005
- Ontario. Canada
Bingo.................Pitt4212 said:jmahler said:Rotax! said:pitt4212, that's what my rep told me as well. I too will not be happy, because the dealer Yamaha rep told me it was supposed to be 30 percent firmer than the proto.
Just wondering why you want such a firm seat?
-J
It's not that I want a firm seat to kneel on, I want the firmer seat so that I sit up higher and so that my knees are'nt higher than my quads. That way there it is easier to go from standing to sitting, vice versa.
SledFreak
- Feb 7, 2005
- Ontario. Canada
I just talked to customer service in Canada, Ontario and they said that the seat has changed considerably from the protos starting with the flap on the seat and he also indicated that the seat is firmer than the protos, but he did not have the actual details on how much firmer they actually changed it.Pitt4212 said:NH Rider said:The seats seem the same as the show sleds last spring
The base of the bar mount is still the chrome plastic cover.
If the seat is still the same softness as the prototypes I am going to be very disappointed with Yamaha b/c all I heard in the spring was that the seats would definately be firmer on the production sleds. That is a major disappointment!!!!! Still hoping.
Pullinfront
Here are some pics from an 06 Vector GT skid frame.
the W-arm
W-arm
ra boot
I have somemore will post later, check out the RS section for pics of the sled.
Pullinfront.
the W-arm
W-arm
ra boot
Pullinfront.
Tork
Pullinfront,
What great pictures!! and you hosted them at imagetex so the would be nice and big, fantastic job.
Looks like the pivot arms are different, some gusseting welded in.
To be sure I'd have to see an 05 RX, but it sure looks like it
Pullinfront
Some pic of the zerk fittings. You can also see some in my 1st set of pic above.
Pullinfront
Pullinfront
SledFreak
- Feb 7, 2005
- Ontario. Canada
Please post more pics of the whole sleds.
RX4RACING
I saw a blue Attack on the dealers showroom floor. Great looking sled!!!
I made the following obervations. The skid has 7 zerks in it. 4 - on pivot points and 3 - on cross shafts. The running boards are fantastic, these things will grip. The seat is definately firmer then the proto's. The chrome collar around the steering column is so-so. The weakest looking thing on the sled is the handle bar cover which is a 6"x4"x4" vinyl covered block with nothing on it.
ReX
Pullinfront, thanks for the excellent photos.
I compared the suspension to some old picture I have of my 05 and it is a little different. I'm not sure if it will fix the problems 100% though - I hope so...
From what I can see it's the same everywhere except the added gussets at the lower cross shaft (mine never cracked in this area but it might reduce the stress in other areas too).
ReX
Actually I take it back a bit...
One potentially significant change is the cross bracing between the two angled tubes. The two cross brace tubes are farther apart on the old one and much closer together on the new one.
This might reduce some of the flexing of the tube that attaches to the u-brackets (that are broken in some of my pics) and might stop the u-bracket from cracking. It's hard to measure in the pictures, but the metal might also be thicker (or better quality) on the 06 w-arm.
I guess we'll have to wait and see. There is definitely some improvement though and my w-arms laster for about 4000 kms on the 05 typically.
A small reduction in stress might be enough to stop them from cracking (I'm still leaning towards having my next w-arm beefed up anyway).
Pullinfront
Rotax! said:Please post more pics of the whole sleds.
Check out the RS section there are some pic of the sled.
RTX Meirda
Big Question!
Running boards are Aluminum or painted?
Pitt4212
Rotax! said:Pitt4212 said:NH Rider said:The seats seem the same as the show sleds last spring
thanks for the positive info I hope it is correct!
