drunkenrich
i wanna buy a few spare relays or fuses to put in the bag for emergencies. I have apn 09 xtx. What is the most common one to go that will have me stranded on the trail? And where do you recommend i buy them from? Thanks
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You should have some spare fuses in your fuse box. From what I've heard a relay is more than likely the one that will give you grief while on the trail. Buy some of the new updated (red solid state) relays for spares or replace them and hold on to your old ones. Oh yes, your stealer should have them or be able to order you them.
drunkenrich
Which relay we talking about
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
The most common fuse to go is what ever fuse you have your heated shield hooked up to if you have one. You should only have a fuse go if you have a short. It is fairly easy to short out the heated shield wire on the frame.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
I keep a spare relay with me and assortment of fuses(mostly 20 and 30 amp) and a spare main fuse. Fuel pump relay is the most common one that people replace. Like mentioned new updated relays are available for the fuel pump load controll and fan relays.
Check your wiring harness in behind the primary clutch and behind the steering gate/rad mount. Some earlier sleds had problems with a nub on the aluminium casting. I had problems with the harness rubbing on the steering gate where the rad mounts. A few others that I've mentioned it to have found spots where it's been rubbing through there as well..
tony_plants
- Feb 16, 2012
- Battle Creek, MI
- 2013 Nytro XTX 144" 1.25 Lug
I have a 13 XTX, replaced fuel pump relay w/ new red relay kept old one (black) just in case....mine was the very first in line (front) out of the four under front hood...I carry an assortment of mini, glass and regular fuses...just to be safe and help other riders out...same with #*$&@'t zip ties....check out the thread Grizz and others put together....VERY helpful...http://www.ty4stroke.com/threads/fault-codes-relay-fuse-location-wire-diagram-diagnostics.83992/
drunkenrich
Where should i get the red one? Price?
tony_plants
- Feb 16, 2012
- Battle Creek, MI
I was able to convince dealer there was an issue, they replaced it under warranty...I'd check ebay first, then dealer....I buy a lot of my stuff from cyclepartsnation, but it's a local pick up for me (no S&H)....I think it ran under $30....
drunkenrich
Should i use the part number on the page you posted for the red one?
tony_plants
- Feb 16, 2012
- Battle Creek, MI
http://www.ty4stroke.com/threads/updated-relays.131941/Where should i get the red one? Price?
tony_plants
- Feb 16, 2012
- Battle Creek, MI
8GN-81950-00-00Should i use the part number on the page you posted for the red one?
tony_plants
- Feb 16, 2012
- Battle Creek, MI
And my guess at $30 was way off....should find it for less than $10 to include shipping....I was able to convince dealer there was an issue, they replaced it under warranty...I'd check ebay first, then dealer....I buy a lot of my stuff from cyclepartsnation, but it's a local pick up for me (no S&H)....I think it ran under $30....
drunkenrich
Port yamaha has them for $12.47
Anyone know any cheaper places?
tony_plants
- Feb 16, 2012
- Battle Creek, MI
http://www.ebay.com/itm/Yamaha-8HG-..._Accessories_Gear&hash=item259f46c0de&vxp=mtrPort yamaha has them for $12.47
drunkenrich
Those are different numbers
