YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
The cordless drils are in the 1300-1700rpm range and my corded drill is rated at 2700 rpm- that's likely your problem. Borrow one and see if it makes a difference. Also, the bigger diameter buffers will have more surface speed.
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
newfie09xtx said:not sure the rpm's but i was using a makita lithium ion cordless drill 18v. i know corded drills work better but i dont have one. I tried all different buffer sizes. It is noticably better but i want a more mirror like shine, without wet sandingYammyRX1 said:What RPMs and buffer size were you using? That makes a big difference too and probably generates heat that helps with the buffing compound.![]()
I purchased the Buschs aluminum polish that was recommended earlier. Awsome stuff !! I dont even use the white , brown,black paste that came with polishing kit. I did both my sleds and didnt take that long. Wool pad on a variable speed automotive buffer works best for me followed by a cotton bonnet for final pass. I only use the polishing wheels from the kit for hard to reach places.
- 12K
