Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Has anyone put the Mountain Addiction Gas tanks on the Yamaha nytro xtx? I'm gonna do it soon and just wanted some ideas. Thanks
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
same as above^^ I have an under tunnel exhaust though so I have a small bag that buckles right in front of that tanks and goes under the seat a little bit. I removed the exhaust bracket and rear plastic so from the rear its open but the side plastics behind the seat is still there.
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Pictures?same as above^^ I have an under tunnel exhaust though so I have a small bag that buckles right in front of that tanks and goes under the seat a little bit. I removed the exhaust bracket and rear plastic so from the rear its open but the side plastics behind the seat is still there.
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Does any heat shield tape work? Like it sticks all winter and doesn't come off?I have them on my xtx...
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
i dont have any on me and my tunnel is currently off for powdercoating. what do you need pictures of?
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Just the tanks on the sled for some ideas, but ok that's finei dont have any on me and my tunnel is currently off for powdercoating. what do you need pictures of?
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
It sticks but you have to watch it...I had to drill a new hole for the pin in the track to keep the cans out of exhaust...this winter I'm getting a stainless shield made. I also got a wicked deal on a trail tank so I'll only need the MA tanks for long trips.
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
mine are in the same spot as UPEI93's but I don't require heat tape or anything since the exh is under the tunnel.
a turn out is a must for added safety so the exhaust isn't hitting the MA container(s) directly.
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Better pic...
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
mine are probably another inch or two back from that. as long as you use two bolts per mounting stick deal it will hold just fine!
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
I was thinking of putting the cans on the others direction so that the cap of the cans are facing to the left or right instead of the back. I think that leaves more room from the exhaust, but not sure yet. What do you think?Better pic...View attachment 111271
SnoBird888
- Sep 4, 2013
- Neenah, WI
- 09 Nytro xtx
i think the tank will stick off the back then but you will gain the space right behind the outlet then. only way to know is to mock them up and just do it!
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Alright, ya I am just gotta straighten out the tail light on the back and maybe raise the MA rails a little, but it should work, I'm hoping to be able to do that soon, just waiting for the store to get the kit in.i think the tank will stick off the back then but you will gain the space right behind the outlet then. only way to know is to mock them up and just do it!
fubar8182
- Nov 5, 2014
- 02 viper / 13 nytro txt 1.75
Matthew457
Any luck with that? I am headed up to qc in 2 weeks I have a 2013 nytro SC mpi stage 1 and going to need the gas. Was wondering what u did with taillight etc pics?
Anythong u can do to help thanks
