srx74
Hi all,
I have a S/C Nytro...a blast to trail ride! but It did not seem to hold up to the bumps. The SC oil tank mounting bracket snapped off. Has anyone else had this happen? if so has someone making a more robust mounting/ vibration isolation kit?
Thanks for any help,
Eric
SRX74
Eric
SRX74
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
Mine broke on my RX1. I just had it welded. I thought the Nytro used the stock oil tank? When it's lite the chance of breaking gets higher. Just remember how much fun it is to ride when you pay for the welding...
stephenpen
I just noticed mine was cracked. Its still attached but not for long.
srx74
I think I am going to make something better than these hose clamps to hold the charger oil resovoir I found some brackets for 3" sanitary tubing at WWW.BEHRINGERSYSTEMS.COM
someone from mpi feel free to chime in here. Do the kits going to yamaha have a more robust resovoir mounting bracket design???
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I beat mine pretty good and never broke, at least that i noticed, I'll take a peak at it tonight. I was thinking they were fairly robust, maybe not.
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
I had to fix mine again this year.
sledingtime
- Dec 12, 2011
Mine is falling apart as well. Are you guys just welding it back together?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
this is crazy. That tank mounts pretty solid on my attak. I guess if a nut/bolt came loose, then maybe I can see it vibrating a bit to ad stress.
I better take a closer look at mine as well then. lol
Ratpack
- Oct 11, 2006
- Frewsburg NY
- 2003 RX1
ya, just welding it. It just cracks where the bracket hooks to the tank.
kinger
- Jan 17, 2005
- Clear Lake, IA
Checked mine after 3 years of beating still perfect. Lucky I guess.
srx74
Gizztracks is in the process of doctoring up my subframe, we explained to him the issue with this bracket...so I guess Ill see what he comes up with and post a picture.
In the mean time I'm dealing with the lack of venting, leaking exhaust, overheating, poor idiling, misfire at 6K rpm, 10th pair of new sliders, shot front bushings, small gas tank, etc...
kinger
- Jan 17, 2005
- Clear Lake, IA
srx74 said:In the mean time I'm dealing with the lack of venting, leaking exhaust, overheating, poor idiling, misfire at 6K rpm, 10th pair of new sliders, shot front bushings, small gas tank, etc...
Wow that is a long list of frustration! I got so lucky with my MPI apex once the initial bugs were worked out (much shorter list) Its been turn key. I dont even check the belts anymore. I dont even change the oil filter just oil once a year and try to keep the chassis together. The engine/SC has been flawless.
srx74
kinger
- Jan 17, 2005
- Clear Lake, IA
Man god love ya for working through all those issues. It will be a very nice machine once completed.
Great outline of the issues and solutions.
Good Luck!
Good Luck!
