blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
does any body have the settings for
stage 1 fuel settings apex no blow off
and settings with teds blowoff valve
it has the updated gems
i blocked off the blow off because it
seemed to have a transition hesitation
changed settings and never could get it
correct and im not talking about
off idle hesitation
when its blocked off i only get 60-70 miles
per tank but runs great
riding in the up michigan
probably 100-500 above see level
thanks
duane
off idle hesitation
thanks
duane
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Are you running the updated fuel pump system that sells seprate from the kit? I had a hesitation with mine, and the a/f reading was high. Telling us we needed more gas. Heath @ MPI informed me that once you go over X amount of boost you need the added fuel pump to eliminate the hesitation. I think he said for over 9-10lbs on my Nytro. Not sure on the Apex. He said mountain guys don't need these when they are over so much elevation. That is probably why the kit I bought, didn't have it with it, but flatlanders do. Good luck keep us informed on the progress
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
I do have TWO blower yamahas and I can't imagine riding without a BOV... being at elevation or not does not change a thing about this.
My kits are not MPI, but a blower is a blower afterall.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
got one on mine. Better for the gas mileage also
- 6K
- 7K
