Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Has anyone tried repairing the soft heat shield on their sled? Muffler is doing a number on it on the inside. I was thinking foil heat tape but not sure if it could handle the heat. Thoughts?
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Found some 3M tape good to 600F
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Does anyone know how hot the muffler gets? Can seem to find anywhere to buy that tape from here. Might have to buy something with less of a temperature rating.
BV1200
Alot hotter then 600deg. F. Ha
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
use DEI from performance improvements or summit racing, i did mine in gold 1100 deg
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
The part I want to repair is part #15 where it touches part #3. It touches the exhaust shield so I would think that is not as hot as the exhaust. Not sure that DEI stuff would work. Isn’t it a wrap? I tried to upload a pic from my sled showing spot I’m talking about but I keep getting an error message saying file is too big.
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Found this pic online for reference. It’s burning/deteriorating on the inside of the circled area, but just the outside covering on the blanket. The insulation inside seems to be fine. Thought maybe high temp foil tape to repair
Turboflash
- Mar 18, 2019
- Southern MN
Maybe Thermo Tec has something? They have a bunch of different heat shielding materials. I've used their products for years and found it to be high quality. Link: https://www.thermotec.com/products/heat-shields-and-protection/stainless-steel-clamp-on-heat-shieldFound this pic online for reference. It’s burning/deteriorating on the inside of the circled area, but just the outside covering on the blanket. The insulation inside seems to be fine. Thought maybe high temp foil tape to repair
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
you can get DEI in a roll or 32' and it is just enough to do the WHOLE inside of side panel.... looks like the legs on the lander on the moon!! you can also get it in a 2'x2' sheet and thats what i did my curtain in... its good to 1100'
Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
Does that DEI stuff have an adhesive on one side or did you have to attach it somehow?
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Turboflash
- Mar 18, 2019
- Southern MN
Thermo Tec also has products with adhesive on one side. https://www.thermotec.com/products
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
yes its adhesive on back, would love to load my pic of it, but on this site it keeps saying file is to big... the tunnel shield for race cars is thicker material.... but the gold or silver ...in the tape or sheet form is 1100.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Why dont you just buy a new heat shield. Lots of race sleds out there, you should be able to find a good used one too.
slimjim2525
Silly question. Can you put the DEI barrier on part 3 in the parts diagram? Would it be worth it, or better to put it on the inside of the plastic. I have to say I'm always a little nervous of the plastic melting.
