mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
Went to move the old apex around this weekend and had an issue. Hit the key and it fired right up but then promptly died like I hit the kill switch. Go to fire it back up and have nothing. No gauge, fuel pump, crank. It's like I pulled the battery. Haven't dug into it yet other than a voltmeter on the battery leads and have plenty of juice there. Ideas??? Ground blocks? That funky looking green fuse? Or ? Thanks
try the fuse block and check also at the solenoid for corrosion. few guys had them full of green corrosion last season. then i would check the relays for the same.
let us know what you find as i have a few more places for you to check if not these.
unclearpine
It sounds like ground blocks.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Any mice poooopies in there?
If so, look for chewed wires in the most remote areas.
If not, see above posts...
mysledblows
- Jan 23, 2007
- Central MN
- Jenkins, MN
Thanks guys. Need it to cool off a little or get ac in the shop before I'm going to wrestle it out of the trailer. Will keep you posted and if anyone has the "I had the same issue and here's what it is" solution don't be shy about posting it up.
mysledblows
- Jan 23, 2007
- Central MN
- Jenkins, MN
Update - after chasing my tail with this one for 2 seasons, ground blocks, cleaning, looking, testing, I finally broke down and put a whole new stator system in it and it seems to have solved all the electrical issues I was having.
