humpy
- Nov 28, 2007
I have a clutching question for you techy guys. 2009 Apex ER - stock clutching(Yellow-Silver-Yellow) long spring in the primary. Current engagement is about 3700-3800 rpms. I would like to raise the engagement to about 4500 rpms, but maintain the full shift rpm. The yellow-silver-yellow spring is 35-118 kg. What spring should I use to get the engagement up about 600-800 rpms. I see that Yamaha has a 40, 45, and 50 kg option all with similar kg at the shift(33mm). I would appreciate your thoughts and help.
PS. Love this site. Awesome members with great insight!
Yamaha White/white/white 45/119. Have same shift speed as Y/S/Y
humpy
- Nov 28, 2007
Thanks! Can anyone confirm what the engagement would be with the W/W/W(45kg) spring?
humpy
- Nov 28, 2007
What engagement RPM are some of you guys running?
What do the clutch kits do for engagement?
Turk
Tech Advisor
4500 rpm engagement is awfully high unless your drag racing with a lot of studs on a very hard surface.
arcticace
I agree with Turk.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
ditto...and will blow the track out in most situations... why the engagement raise?
