Da Yammie
Well I haven't been here in a long time! But we finally have snow here and my phazer won't start... the trickle charge says it is 100% charged but when I try to start it it is only cranking at 210rpm and won't start. I assume the battery is toast so I went to order one but "royal distributing" says their batteries are from 09 to 12 will they fit in a 08?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
They're all the same battery, YTX14-BS. Royal's catalog is not listing 07-08 for some reason. Try Amazon. They have the YUASA cheaper and ships for free.
https://www.amazon.ca/Yuasa-YUAM3RH...=UTF8&qid=1485131084&sr=8-1&keywords=ytx14-bs
But before you invest in a new battery, have you tried boosting it with another battery with jumper cables or a booster pack?
Da Yammie
Haven't tried boosting it and when was the last time you order a battery from them? Ordered one about a year ago and it came with the acid.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
My bad, I corrected my post but you got the email notification first with the original post. I misread on their catalog that they don't ship with acid (only a few that they don't).
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
The 2 bolts that hold your starter together may have come loose which can cause excessive power draw/slow starting.
No show
You can get these batteries at any battery supply store if you do need one. I had to get one last year and it was $80.00.
Jory
- Mar 20, 2016
- Alberta
- 2007 Phazer MTX SC
I deal with saskbattery, they add the acid and seal it before shipment, plus very good customer service. Also went with the YTX14H-BS as it's the same size but 240cca $109.50 shipped.
Creeksider
- Nov 16, 2014
- Kemptville Ont.
- 2010 Yamaha Phazer
ETX-14 AGM from Car quest. The best battery I've ever owned. No liquid acid to overflow or spill. I just replaced my previous one that I purchased in 2009. The only reason I replaced it is that it just didn't have enough cranking power when it's colder than -15C. Paid $120.00. I paid 60ish on the first one because they were on sale.
jason22
- Feb 28, 2014
- Newboro Ontario Canada
- Yamaha Nytro
I pick up a Yuasa YTX 20-HL. It has 310cca
Vs the stock 270cca.
And I beleave it was $130 Can.
For my '13 Nytro
For my '13 Nytro
Jory
- Mar 20, 2016
- Alberta
There is liquid acid in there, it's trapped in the Absorbant Gas Matt (AGM). More CCA will help in very cold weather but a battery heater is the best.
