unreal
Just installed a MPI supercharger on my 06 Apex mountain. Came to fire it up for the first time and I get code 15, and 84 any ideas?
unreal
don't worry guys got it under control TORS
Don't worry about it, got it fixed and going to try it for first time tommorow.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Code 15 will come up every time , but will go away as soon as you start engine ,
Code 84 , bypass the tors !
You will love it !!!!!
unreal
got her going
Yup, figured that out. But thanks again guys, goes AWESOME.
HOBB-Z
codes
I have a code 43 and 46 it still runs but I don't know how to reset them,
my sled is a 07 mtn apex.
Any info on resetting them would be great.
Swiss Sledder
ERROR CODE RESETAny info on resetting them would be great
- Kill switch in the on position
- Hold select and reset down on your gauge pod
- Turn ignition key on
- Wait 8-seconds
- The gauge will display DI
- Let go of the buttons
- Momentarily press the reset button to cycle through until gauge displays 61
- This is where codes are stored (if there is more than one it will cycle through them)
- Momentarily press reset again until gauge displays 62
- Use your grip warmer rocker switch selecting the down position to delete the codes
Note: Anytime you power up the gauge pod with components unplugged you will trip error codes. So if you have any connectors disconnected and power up the gauge pod you will have tripped and stored error codes.
Reference Post: http://www.ty4stroke.com/viewtopic.php?t=29536
HOBB-Z
Thanks for the info, you saved me alot of time
