Blown14psi
stoutner said:Don't go with too big of a shot. If you do, you'll run out way too early.
Just buy 2 extra bottles and carry them in a backpack. Or I'm thinking of buying a Cold Fusion or Boondocker Carbon Fiber 4lber. Spendy though.
stoutner
Yeah, a lot of Jing for those Carbon Fiber bottles. Also, every 10 second blast of the juice costs you about $2 - $5 depending on the size shot.
....hmmm, hookers are cheaper than that
Black 1000
You are absolutely correct. I have 2 2.5lb bottles and with a 60 shot they don't last long. I am considering just leaving well enough alone cause I only use it for fun
yamahaboy_15
i was thinking of at least a 40hsp power kit but if i will run out i could go to bossnos and buy the nos kit that goes underneath the seat, the bottles are atleast a good 5lbs
Blown14psi
yamahaboy_15 said:i was thinking of at least a 40hsp power kit but if i will run out i could go to bossnos and buy the nos kit that goes underneath the seat, the bottles are atleast a good 5lbs
They fit a 3lb bottle. They told me you may be able to squeeze a 5lb Carbon fiber, but it would be tight.
I think I can fit a 4lb carbon fiber bottle under the snout. They are a about the same length as a 3lb but are a little wider.
yamahaboy_15
yah if i did that would be alot of juice
- 13K
