hereismylife
It seems like some say no seal available you have to buy the shaft. Not understanding if these keep failing there should be a replacement seal. Anyone have any updated info on this?
They break it down on newer models.
hereismylife
I will take a look. Is it different is the question?They break it down on newer models.
Can't say with 100% certainty.
Try it.
Try it.
hereismylife
You know how that goes. I think the newer seals are bigger. Just looked at both diagrams. Still don't understand why they did that design to begin with.Can't say with 100% certainty.
Try it.
What design?
What are you out if it doesn't work. About $20
It's a no-brainer imo.
hereismylife
Going to make a call and see if port knows what the deal is. I don't want to down sled yet unless I know what is going on. From what it shows you have to buy the whole shaft. Just baffles me no one really changed this or did not report back after doing so..lol. not like the 2 stroke stuff. This is a odd ball I guess. But yes shipping is like 16 plus parts. Get pricey. No dealers around anymore.What design?
#24 in attatched link picture.
It's been years, but I think I did do this before and it worked.
2012 Yamaha APEX (RX10PBB) Crankshaft Piston | CyclePartsNation
Shop online for OEM Crankshaft Piston parts that fit your 2012 Yamaha APEX (RX10PBB), search all our OEM Parts or call at 269-385-1540
www.cyclepartsnation.com
hereismylife
Ok. Thank you. Will see. Will update once I get more info#24 in attatched link picture.
Shop online for OEM Crankshaft Piston parts that fit your 2012 Yamaha APEX (RX10PBB), search all our OEM Parts or call at 269-385-1540www.cyclepartsnation.com
hereismylife
UPDATE !!!!! I can't believe the answer I heard. Not sure why it happened. Also it was never updated for some reason.
Answer is they never added the breakdown to the seal like the newer Apex or older rx1....lol I was told to use the 05 rx1 lookup
not the 1st time i have gotten an answer out of a dealer like that.
I don't ask the dealer to look parts up for me. Way too many mistakes and/or questions.UPDATE !!!!! I can't believe the answer I heard. Not sure why it happened. Also it was never updated for some reason.
I just give the part number and quantity.
Just order the seal from the 2014 and put it in.
