DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Back ground : 2008 Vector. About 5800 miles . I really like the sled and have it decked out the way I want so would like to keep it for a backup.
So , some place I have an exhaust leak and the sled is rather loud. I talked to the service department at the big dealership in town and they said depending what’s wrong between 1000 to 1400 dollars to fix and won’t know until they tear it apart.
I have repaired my exhaust on my 09 so I’ve done it before. That one was easy the pipe broke in two lol .
This one kind of has me stumped…. It reacted and sounds like a donut problem but there is already copper ones in place and they look to be in good shape . The flare outs look good and not broken . I’ve primed the carbs and started it and I can’t see where it’s leaking . The gasket looks to be intact and no burn marks by the manifold.
So what do I check from here ???? Pull the muffler total off ?? I have the sled up and the suspension out so it’s total exposed and no signs of leaks when started .
Thanks in advance!!
Thanks in advance!!
paradise
Could plug your exhaust and start it to see where it’s coming from, probably only be able to do that for a short time.
theCATman
Does the sound seem to be coming from up front, or the tunnel??
They are known to crack where the mid pipe meets the tailpipe. Which would be roughly just forward of where the track makes its bend over the upper idlers going forward.
DGZRT
- Feb 23, 2006
I will plug the tail pipes again. I did it before tearing it down and kept right on running so I figured the donuts. I will plug it again and see where the exhaust spits out .
It sure sounds like right by the motor
paradise
I wouldn’t think it would blow out where it’s bolted to the engine but you never know, I thinking it could also be in the flex part of the pipes.
theCATman
Yep. If it's not at the midpipe tailpipe junction, I'll bet it's a cracked flex pipe/pipes
DGZRT
- Feb 23, 2006
Having never taken a flex pipe off . Is there a better way to crack those rusty bolts ?? Heat and lube I’m guessing. And NO impacts! Anyone have any awesome tips ?
theCATman
Start soaking the bolts in PB Blaster or Deep Creep right now. Spray them often, and give it 2-3 hours and try loosening them. Heat them too if needed. Also sneak a punch in there and give them a rap with a hammer. Don't reuse them either. Buy new gr 8 bolts.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
I just did my exhaust donuts and took the flex pipes off. Mine came undone super easy. No issues at all. Maybe use the factory donuts. They might seal better. Thats what I used.
paradise
Any luck with finding your issue, just curious.
DGZRT
- Feb 23, 2006
Not yet . Work got in the way . I have been lubing the bolts on the flex pipes . Hopefully remove them tomorrow night .Any luck with finding your issue, just curious.
MitchRS
Honestly, you might as well replace all of your flex pipes with the braided flex pipe fix from F/X Garage Works. It ends up being cheaper than the stock Yamaha flex pipes and should last much longer.
The stock flex pipes and gaskets keep blowing constantly so why not just upgrade and not have to worry about it.
DGZRT
- Feb 23, 2006
I'm pondering that right now. I really like the idea but watching his videos seems like you need to do it just perfect for it to seal.Honestly, you might as well replace all of your flex pipes with the braided flex pipe fix from F/X Garage Works. It ends up being cheaper than the stock Yamaha flex pipes and should last much longer.
Have you done this fix ??
I first want to be sure its the Flex pipes and not the pipe running down to the muffler.
MitchRS
It’s not as complicated as it seems, I recommend you use a hacksaw when cutting your pipes since you’ll have more of a precise cut. I used an angle grinder since that’s all I had at the cottage and it still worked out well.I'm pondering that right now. I really like the idea but watching his videos seems like you need to do it just perfect for it to seal.
I did, I thought I had posted here but it seems I had posted it on snowmobile fanatics since I hadn’t found this site at the time. https://www.snowmobilefanatics.com/...f-x-garage-flex-pipe-kit.143329/#post-1351581
That’s a good idea, mine was leaking at the mid-section as well but it had no clamp and a bad gasket lol. My stock Yamaha flex pipe broke at the spring portion and broke off at the welds..
DGZRT
- Feb 23, 2006
Your install looks great good job . FYI you’re missing a cotter pin on your nut on the steering arm just above the pipes . I’m just glad this is my backup sled .It’s not as complicated as it seems, I recommend you use a hacksaw when cutting your pipes since you’ll have more of a precise cut. I used an angle grinder since that’s all I had at the cottage and it still worked out well.
That’s a good idea, mine was leaking at the mid-section as well but it had no clamp and a bad gasket lol. My stock Yamaha flex pipe broke where the spring portion broke off the welds..
