Mike McKenny
- Oct 31, 2020
- Quyon
- 2021 Yamaha Venture
Hi everyone,
I have a new 2021 Venture, with only 2 miles on it so far. I have started it up about a dozen times or so, and each time I go to start it, it won’t idle on its own until after the 3rd try turning the key and rolling it over. The 1st two attempts, it may idle for 1 second or so, and quit. Each time I turn the key to on, I wait until I hear the fuel pump go off, then I crank it over.
Is there a trick to getting these to idle after the first try turning the key? This is my first fuel injected sled.
Thanks!
Mike
Thanks!
Mike
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
These sleds don’t like to be started and shut off a lot without being fully warmed up. You can start to foul plugs from that. Wait till you get some run time with fresh fuel in it and it gets cleared out and then see how it responds
Mike McKenny
- Oct 31, 2020
- Quyon
Thanks for the advice. Each time I have started it so far, I have let it idle for about 5 minutes, and gave it a quick drive around the yard. It will start fine when it is warm. It is inly when I try a cold start when it takes about 3 different tries
greatwhite89
- Mar 19, 2015
- Oshkosh, Wisconsin
- 2020 Yamaha RS Venture TF
- www.snowflapjunkie.com
My 2020 does the same thing. You'll get more used to it, but still annoying I agree. You will love the sled though. Over 3,000 happy miles on mine. The white paint on the 2021 looks fantastic!
Mike McKenny
- Oct 31, 2020
- Quyon
M
Thanks Greatwhite89. I agree, love the white and blue. Still waiting for enough snow for the trails to open up here. Getting anxious!
mooseflyer
Hi everyone,
Thanks!
Mike
That doesn't sound right for sure. My 2013 TF has started every time, reliably, since new. Sorry I'm not an expert so can't comment further.....
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
The reason for getting a fuel injected is so you don't have to play with it to keep it running when it's cold!
Something needs attention.
My sled only does this when transferring it from my barn to my toy shed, just before the snow flies. It was parked for 8 months, and never started.
Always properly stored, with fuel stabilizer in a full tank of gas.
27 000 km later, I still don't have to do what you are doing.
As for starting it to hear it, etc., DON'T. You'll foul the plugs, and then have lots of fun replacing them!
5 minutes doesn't warm the engine, 10-15 may be enough.
You could let it warm up until the temperature light comes on, then shut it off. No, the temperature light coming on will not damage the engine.
People treat their sleds like they are a delicate flower which needs constant pampering. It is a machine.
JasonR
- Dec 28, 2020
- Kawartha Lakes
- 2016 Vector XTX LE 1.75
As the others have said, get at least one good run on it before you worry too much.
Depending on how long the fuel has been in it maybe a bit of conditioner to ensure there is no moisture.
Hopefully just a bit of carbon buildup on the plugs from not getting up to full temp and hard run will fix it all up.
Derek Fosbury
- Jan 18, 2021
- 2022 Sidewinder S-TX GT
2025 SRX
- Sledding Location - Fenelon Falls, ON
Hi everyone,
Thanks!
Mike
Hey Mike - I bought the same sleds, and had the exact same behaviour until I went for the first long run and got rid of the gas that was supplied by the dealer. Now they start first crank every time. Anything from +3 to -15 deg C weather over the past 3 weeks.
Mixlflick
- Nov 5, 2020
- Wisconsin
- 2021 venture rs tf
2018 polaris ltx550
Have the same machine - has started flawlessly. Like others have said stretch its legs and get it moving it should clear up.
Derek Fosbury
- Jan 18, 2021
2025 SRX
Quick update on this to share another observation
Roger
- Feb 10, 2007
2006 Indy 500
If you pull out that white sleeve, you'll likely get a few more litres of fuel in there.
If you're away from civilization, gas stations are becoming rarer than an honest politician!
I carry an extra 4 litres container in my trunk, and have used it!
Derek Fosbury
- Jan 18, 2021
2025 SRX
I'm interested the container you put in your trunk. I had the same thought, but didn't think with the small opening that I could get one in there. What container are you using, if you don't mind my asking?
Roger
- Feb 10, 2007
2006 Indy 500
It's just a 1 gallon red plastic gas container. The same as the 5 gallon one you use to fill your sled at home, but smaller!
It's only about 10" tall, and it barely fits!
Derek Fosbury
- Jan 18, 2021
2025 SRX
cool, thanks!It's just a 1 gallon red plastic gas container. The same as the 5 gallon one you use to fill your sled at home, but smaller!
