targabill
The Ignition switch plug about 8" from the Ignition switch itself is very corroded, I need a new Female side on that plug to wire in, maybe with pig tails would make it easier.. Does anybody have a link to this plug, It's easy enough to clean the pins on the male side so I don't need to replace that..
Thanks Much.
-Bill 08' FX Nytro..
Thanks Much.
Can you post a picture?
targabill
I usually can find the connectors on EBay or Mouser.com
6 Pin DT04-6P DT06-6S Waterproof Electrical Connector For Deutsch | eBay
6 Pin DT04-6P DT06-6S Waterproof Electrical Connector For Deutsch.
www.ebay.com
targabill
Thanks, I was hoping to find the same connector and keep the male side as it looks fine, but I could replace the whole connector.
Also, If I replace the ignition switch it will already have the correct connector..
You should be able to find that plug on mouser. They have a help area too.
targabill
Maybe, I was looking, There are 1000's of connectors.. Without a part number it is hard to find it..
Thanks for the reply...
You might be able to use the live help and send them an image of plug.Maybe, I was looking, There are 1000's of connectors.. Without a part number it is hard to find it..
