zrnewf
- Feb 8, 2005
Hi everyone.
i have been sizing up the RX warrior for a while now...and im bitting the bullet and picking up a used one this summer.
the plan is to use mountain performance's supercharger, alot of lightweight goodies, fox shocks, c&a's, and a few other things.
how does everyone find their warriors.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I like mine!
It's an 04 Blue Warrior with 4750 fast miles on it
That have been trouble free
I have the O/S/O primary spring, the secondary shimmed for overdrive, NGK 10 spark plugs and it now revs 10,600 and hits 123 MPH on the speedo
Prior to these changes the best I would see was 112MPH.
I just replaced the main jets to 137.5 and went up one shim position on the needles and installed Green carb springs and I'll be trying this next week in Quebec if the weather holds up 8)
Prior to these changes the best I would see was 112MPH.I just replaced the main jets to 137.5 and went up one shim position on the needles and installed Green carb springs and I'll be trying this next week in Quebec if the weather holds up 8)
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
BEST SLED I HAVE EVER HAD.
zrnewf
- Feb 8, 2005
what do the carb springs do?
Bob Miller
- Apr 19, 2003
- New Milford CT
zrnewf said:what do the carb springs do?
This is from there website! I'll let you know after I try them
We have found some "easy" horsepower in these slide springs, specifically designed for three altitude ranges and inlets (stock or modified air box or carb filters) for the Yamaha RX-1 snowmobile (see table below). Improved throttle response and up to a 1000 RPM increase results from the use of these springs. A set of four springs come in a convenient carrying tube . For Vector applications, please call.
Mikuni CV Carb Slide Springs for RX-1 Snowmobile
© 2004 Holtzman Engineering, Inc. All Rights Reserved
Holtzman Engineering, Inc. - 3907 Evergreen Road - Eagle River, Wisconsin 54521
Phone: 715-479-8727 Fax: 715-479-2196
Email us at: holtzeng@direcway.com
yamahajunkie
bob i see the r's are up, did you take the rivit out of the primary?
- 10K
