STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
It looks like Hurricane is making their own clutch weights again. Big pull clutch arms?
I just noticed them on their site. Has anyone had any experience with them yet?
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
I'm looking at their 240 SM tune. It comes with them. If i do get it and we get a winter again I will report back
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Just looked at them, everything I had been feeling I needed when adding weights to my heavy hitters this seems to want to cover in a little diff way. Always felt these sleds wanted/needed a weight that is heavy at the heal to help with acceleration and that’s where a lot of the slipping came from.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
They seem to have some resemblance to the stingray flat profile weights I had in my adapt for a while. Hurricane weights have some extra mass in the heel though. Really liked those stingray weights on the adapt. They take more weight due to the profile and not quite as responsive as lighter weights of course but they pull really hard and cool belt temps. No slip!
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
I had the Hurricane 240SM tune added to the winder. Clutching will have Hurricane weights with Orange/ Black secondary spring. Stock helix for now. Once we get snow I will let everyone know the results.
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
So update to the new Hurricane weights. Very happy with the low end pull. Only thing is on the big end I am losing RPM. Hole shot is a tad high I believe. Some times 8800 8900. But when I finally got the chance to hold it for a bit the RPMS drop ( as low as 7950 ) and I get 2 red lights flashing on the dash. Track was re-tightened. If anyone else is running these weights are you having the same issue? Other question is do I need to change my helix from a reverse helix to a straight or 39/35 ish?
As always that's for the help.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
The lights are warning you of engine “knock”
Get out of the throttle immediately when you see this warning.
Boost leak? Weight too heavy?
8900 rpm is fine if it holds it. How much weight are you using?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Why are you pulling it down to 7950? Take some tip weight out of it, you got to get that RPM up in the 9000 even 9100 range on the top end with a tune and big muffler. The low RPM will cause deto. thats why the dash is flashing at you. Don't want that to be happening too many times or ever for that matter. Get some Boostane in the tank if you cant clutch it better than that also. You are in need of a different clutch recipe and serious help if you are pulling the RPM down like that upstairs, you're 1000 RPM off. Could also be down on power and not able to pull a known good clutch recipe. I don't know anyone running these weights so cant help you there on what they need.
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
I reached out to Dave at Hurricane to find out. Response i got was weights are setup and shipped for his tune. Waiting for another response back for the low RPM and if I should not be running the reverse helix. Was going to try another helix.
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
Update
Found stub shaft was moved in from factory. Corrected and installed CHP stub shaft washer to prevent future movement. Called Dave and he had me move weight from tip to heal and remove 4g total from tip. Now at 71.1g for weights. Nothing in the tip. Offset is now at 60.5mm no washer behind secondary. It might be a day or so before I can run it and report back. Thanks for the pointers. Will do one thing at a time until we get it.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Rb2001srx700 is also using 825 belt
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Depending on secondary set up, this sounds like you are in the ballpark with total weight.Now at 71.1g for weights
I know the Dalton weights may be a different profile, but with a 240 SM Hurricane tune and Dalton weights, @ 71.5 grams was where I was ending up on a Yamaha primary clutch.
It seems Dave always recommends really heavy set ups for his tunes. The few I have seen with his recommended weight always needed quite a bit of weight pulled out of the primary to work correctly.
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
Secondary is wrapped at 80 Dalton spring black/orange stock 35/39 helix.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I always got rid of the reverse angle helix on tuned sleds. I didnt feel it was needed. I always felt the reverse angle was to combat turbo lag, which I never found to be a problem.
Straight 35, 39-35, 41-37 are the angles I used.
Your results may vary.
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
I will see how this works out for now and will get a different helix for next year. Thanks for the infoI always got rid of the reverse angle helix on tuned sleds. I didnt feel it was needed. I always felt the reverse angle was to combat turbo lag, which I never found to be a problem.
- 6K
- 17K
