vicman
Just got all my plastic painted!!! I have a ton of hours into smoothing the side panels. Black with Thunder Blue Pearl. Will post more pictures when I get the sled all back together.
Bluebullet
- Mar 19, 2005
- Massena NY
- Maine
Wow, I like it can't wait to see it put back together and on the sled. That will be sharp on a snow covered sunny day! Nice job!
steve barber
nice looking paint, could you tell us what steps was taken to get to that point?
Paraclete
Looks great. Nice work
Super Sled
- Feb 25, 2009
- Summit X
Dang, looks sweet!
Nick1945
Very nice paint job
bottlerocket
Man that makes my hands hurt looking at the hard work you put into that. Looks awesome!
n.e.mich
Bluebullet said:Wow, I like it can't wait to see it put back together and on the sled. That will be sharp on a snow covered sunny day! Nice job!
X's 2! I bet that will look great, take some pics once together in natural sunlight. looking forward to seeing it!
vicman
It was a long process! I started by sanding with 80 grit to get the texture somewhat smoothed out. then went over it again with 180 and then 320. after that sprayed it with Bulldog adhesion promoter, let that sit for about 10-15 minutes and hit it with a heavy build self etching primer. Once that dried for about 24 hours it was time to sand it again!! This time sanded it with 400. once it was all sanded cleaned all the surfaces and sprayed them black. let the black tack up and used the bull dog as a binder for the Blue pearl. then cleared all of it. it was alot of work doing it the way i did it.
My advise to anyone who is thinking about doing this would be to save yourself a ton of time by scuffing the surfaces with a red scotch brite, Bulldog, and give it 3-4 heavy coats of primer. Let that dry for 24 hours then sand with 400. It will still have the texured look before sanding but you will be able to smooth that out with the 400 git paper easily. I did this on the lower belly pan pieces because you dont see 90% of them and you cant tell the difference.
toy4dan
IF ITS STOCK ITS IN STOCK !!!
WOULD YOU DO IT AGAIN ?
NICE JOB !
NICE JOB !
snowdust
Are you basically saying the primer was able to fill a lot of the texture on its own?vicman said:It was a long process! I started by sanding with 80 grit to get the texture somewhat smoothed out. then went over it again with 180 and then 320. after that sprayed it with Bulldog adhesion promoter, let that sit for about 10-15 minutes and hit it with a heavy build self etching primer. Once that dried for about 24 hours it was time to sand it again!! This time sanded it with 400. once it was all sanded cleaned all the surfaces and sprayed them black. let the black tack up and used the bull dog as a binder for the Blue pearl. then cleared all of it. it was alot of work doing it the way i did it.
vicman
Yes having done it i would have put 3-4 heavy coats of high build primer sanded it with 400 and i think it would give the same result. worst case you sand and do one more thin coat and sand again. But this would save TONS of time!! And yes i would do it again. i think its going to look good and you dont see alot of apex's with it done.
