jtssrx
jtssrx
jtssrx
jtssrx
ExTrEeMF7
jason i have 2 spare srx rear heat exchangers cant i put one of them on ?
also i cant waite to get mine man your making me all horny
have to give you a big kiss -
that looks wild man when we talk the other night and you sent me the pics man have they changed lol
that is so cool now have to get me to do all the powder coatting and ceramic coatting and we all set
thnx marc
thnx marc
Snow Fever
JTSSRX, You dirty dawg, The guys I've talked to say the Bender kit has some Turbo lag, the MC Xpress guys I've talked to say they have next to NO Turbo lag, I was shooting for "O" Turbo lag and you should be on boost before you hit the throttle!!!!!!!!!!!!! Awsome job so far can't wait to see the final project. Once you get it dialed in it WILL BE THE ONE TO BEAT! You just took the Turbo set up on these sleds to another STAGE. Nice to see not everyone is set on riding the same mule. I'll be watching your posts even closer now. Just keep saying TURBO RX-1, TURBO RX-1 TURBO RX-1 man I just love the sound of that.
jtssrx
Snow Fever
Snow Fever: Thank you for the kind words. I really respect your independant effort on your turbo. It looks great. I could never have built this kit on my own. Bob and Fred who started Lightning Pro are highly skilled. It's been a pleasure watching them work on this project. We are going to be able to provide the public with a top notch product because of there talents!!!!!!!!!
fred kilbourn
- Aug 23, 2003
intercoolers
It should also be noted that this exact carb and turbo is being used on a "BUSA" and it makes 500 bhp without intercooling. The Yamaha motor will also make huge power if one cares to go into the engine and install heavier rods. However we really need to dismiss the power that is available with this and other set-ups. The real issue is trying to get the power you have to the ground, without destroying your drive line. A well designed turbo will develop more power than we can use, so we should shift our thoughts to power management and along with that the issues of turbo lag and ease of tuning and reliability.
Also a properly designed turbo motor will live longer at any given hP out put than a normally aspirated motor. reason being is that the connecting rods are never un-loaded under boost. This is easily noticed when the motor is under boost you can feel how smooth it becomes. ie. lack of vibration . Also, a simple alternative to an inter-cooler is water alcohol injection, which is easily to install and very low cost.------- FRED
Silver
Turbo
Hey guys it looks pretty trick.Can't wait to see it in person at the Novi show.Mike
Silver Streak
I can't wait!
SS
SS
Jason and Fred. Looks excellent. Nice fit and finish. Look forward to seeing you guys at the end of september...BBY
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Jason, that thing looks awesome!!!!!!!!!!!!!!! Hopefully you have it at Hay Days, now I just gotta find a place where I can drive that bad boy :lol:
rx1mtn
AWSOME project, pic's look way cool. Looks like a lot of work but will pay off. 1 question, what are you useing for the rear heat exchanger? Or did you make it?
jtssrx
Heat exchanger
It's from a SXR700. I modified the aluminum braket to fit in the RX-1 tunnel. It turned out better then I thought when I started woring on it.
