Hey guys!
Great site with tons of awsome info!!!! Any recommendations for new season checks on a MCX nytro I just picked up (has timersled frt/rear susp with floats). I like doing maintenace on my machines (better the repairs!!) and thought there might be some extra things to check out on this 4stroke with the turbo. my quick check list:
oil level/condition
coolant level
track tension
hyfax / carbide wear
turbo fittings??
grease zerks
clean primary and 2nd clutches
Check valve clearance/shim (only has 600 miles so not sure if needed?)
Anything else to watch for with this MCX turbo unit? thanks guys.
What slymax says, and I have to add; don't stand too far to the rear on the running boards, and for .... sake don't pull the handlebar when you hammer down the throttle like you would on a stocker... before you know it your skis are pointing at the Northern Star (or straight up) flipping the sled over backwards
