nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Hey folks! I talked to my Yammi dealer today about my leaky shock, and the fact that I had a wear mark on the bottom shock eye on my '06 GT. He told me that the track tension may have played a factor in the wear, but he told me that to check for proper track tension you ahould do the following:
Using a fish scale, you should hook the scale into the holes on the track, and it should take 22lbs. of force to move the track 1". I asked if there was to be a certain ammount of droop when the suspension is off the ground, and he said that the tension method is how Yammi wants it!??
Just though I'd relay the tip!! Any feedback, or conficting info. here??
I have planned on adding the wheel kit to the shock, but according to him, if the track is adjusted right, there should be no problem.
Nate
Nate
