Tirebuster
- Mar 16, 2008
- Arnprior,Ontario
- 2023 SRX
Just bought an '06 Venture for a back up and am changing the oil. My problem is how many drain plugs are there on this thing?! It appears that there is only one on the oil tank. I have removed the panel to change the oil filter and expected to find another on there like on the 4cyl models. Thanks in advance.
DaJudge
- Nov 29, 2005
- West Michigan
- '06 Rage
Look for the bolt on the bottom of the motor with a copper washer on it. Pull that out and you should drain the remaining oil in the bottom end.
Tirebuster
- Mar 16, 2008
- Arnprior,Ontario
- 2023 SRX
Found it. Thanks for the help.
Tim
Tim
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
When you take the oil filter off, make sure that you also get the O Ring from the old oil filter off of the engine before you put a new oil filter on. Sometimes the O Ring stays on the engine and if you put a new oil filter on, you will have two O Rings in place. Disaster can follow.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Vectornut said:When you take the oil filter off, make sure that you also get the O Ring from the old oil filter off of the engine before you put a new oil filter on. Sometimes the O Ring stays on the engine and if you put a new oil filter on, you will have two O Rings in place. Disaster can follow.
X2 Don't forget this.
I also like to clean the screen in the bottom of the oil tank.
canadianhunter
I also remove the black plastic plug on the valve cover to avoid a vaccum lock that can keep some of the oil from draining.
Not everyone thinks this is necessary, but I proved it to the dealer that it does happen.
