asti
- Mar 2, 2013
Hi, i would buy venture MP, but i would known if the MP is good in deep snow if i change track for 154x16x1.5 with extension and BIG simmons or similar ski?
It will do better than factory, however i would prefer to go with higher lugs. I run 51 mm on mine and it is a totally different sled, even though i run the same length.
But, if you are going to run in extreme conditions there are better sleds than the mp.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Definitely, this is not a mountain sled but if you look up posts by Karl, he seems to have it dialed in to work well with a 159" track. No matter what track you put on it, it's still big and heavy. It's not a boondocker for sure but it be able to float with a good track and ski combo.
jfaubin
- Jan 14, 2015
- tundra, but i would Venture mp
thanks.
Yes, sure, but all four stroke is big and heavy.
jfaubin
- Jan 14, 2015
do you use in deep snow with 2 inch?It will do better than factory, however i would prefer to go with higher lugs. I run 51 mm on mine and it is a totally different sled, even though i run the same length.
- 25K
