MountainMax
- Nov 21, 2004
- Churchill Falls, Labrador
- 2009 Yamaha Apex
Ok guys, I read the owners manual, and it don't say anything about how to change my 09 Apex MTX oil filter, however I used the Ulmer racing ones, no problem there. I have a question about refilling the oil and bleeding? I see there is an oil cover in the top pan, do I add some oil there or all the oil there? or put some/all the oil in the reservoir. Finally is there any bleeding procedure like on 4 stroke dirt bikes? or just run it like a car and recheck the level in a few minutes?
I have done many searches here and have not found the info I am looking for, so any help will be great, thanks...
AttakDog
just put about 3/4 of a quart in the motor and the rest in the dry sump tank (where you check the oil) run it till hot and recheck no bleeding needed
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
Thanks, now second question, is there a screen we should remove in the bottom of the reservoir similar to my WR450 4 stroke bike too for cleaning?
gotta-b-blue
yes
Yes, loosen up the clamp and remove the screen to rinse...especially if it is your first time changing the oil.
Fergie
- New Jersey-Ride Old Forge N.Y.
yes, there is a screen. but i don't think you have to worry about it until you get some miles on her.
Apex809
Anyone using fram oil fiters?
gotta-b-blue
shavings
I have done the first oil change on 5 fourstrokes and there has been quite a bit of debris in the screen on all of them.
apexgt4life
first ive heard of screan, were is it, i have stock oil system
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Screen is located at the bottom of the oil tank, in a 90 degree chrome tube held on by 2 allen head screws, I believe.
apexgt4life
u mean the dry sump tank, i asume there is a gasket would it have to be replaced
Iceman57
apexgt4life said:u mean the dry sump tank, i asume there is a gasket would it have to be replaced
Yes the the dry sump oil tank. There is an o-ring not a gasket and it doesn't need to be replaced unless you loose it or it gets damaged.
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
I removed it, same as on my WR450 only bigger, and it was DIRTY yuck... cleaned it with degrease and reinstalled.... Oil change (first one) done
wigman1
I brought mine to the dealer and had him take care of it. $90.00, well worth it to me. That thing scares me when you pop the hood off and you can't even see an engine!! Wig
