No low beams-LED
nb-sledder
Moncton
Canada
all of them
Hey guys, I just took a 14 viper in on trade. The guy had installed LED headlight bulbs. the low beams sort flickered a bit when he dropped it off. I didn't think much about at the time. Now there's no low beams at all. Only high beams.. What am I looking for?? Relay?? I can't imagine its the bulbs as there's no low beam on either bulb...
What brand LED?
Might want to check the main plug in the harness for removing the hood. I had a pin get bent on my hibeam circuit and it did the same thing, just have to trace lowbeam wire back to the plug and find the pin associated with that wire. If it's bent you can carefully straighten it with a very small screwdriver!
