yam4life
I own a 2008 VK Professional, for the first time trying to start my VK this year, my battery was totally dead, so i charged it and the machine will run until the battery runs out. I have changed the voltage regulater and still the same results. My battery fails and once again the machine shuts off.
If anyone has expereinced this with their sled please let me know what the solution was to fix it.
yam4life
as anybody had any problems with thier stater
spddmon
ime not framiliar with the vk but a couple of rx1 mine and a friend batteries wouldnt charge traced wires into the nosecone area found a wire chafed through at the voltage regulator
yam4life
The wire that you found shafed was it one of the wires that connects to the regulator.
spddmon
yep
waynes
My first vk pro (an 06) had a problem similar to this and it was to do with the voltage regulator. I now have an 08 and and haven't had this problem but what I do now is every month or so I disconnect the two plugs on the voltage regulator and put some electrical grease on them and put them back together. My dealer told me there is an update for this problem.
I would have this checked out first because I know a couple of guys who experienced this problem as well and it was the voltage regulator or the plug-ins to the voltage regulator.
Hope this helps
Hope this helps
