I am not getting any power on my 07 attak. A week and a half ago I was getting a clicking but no ignition. I do a ton of reading here so I tore it down to the clicking which was the block next to the battery. Slight corrosion so I lightly sanded and put electrical grease. Ran fine until this morning. Fired up fine and after 40 miles I shut it off. came back 2 hours later. Got the clicking again twice and then nothing. No power to the gauges. Tore it back a part. Checked fuses and connections. All good. I put a volt meter on the ignition wires and get nothing from any of them. I am thinking a bad ignition switch. Would one of the relays near your left foot cause this? As always any wisdom is much appreciated.
Have you tested the battery?
I did. The battery is good.Have you tested the battery?
Update:I am not getting any power on my 07 attak. A week and a half ago I was getting a clicking but no ignition. I do a ton of reading here so I tore it down to the clicking which was the block next to the battery. Slight corrosion so I lightly sanded and put electrical grease. Ran fine until this morning. Fired up fine and after 40 miles I shut it off. came back 2 hours later. Got the clicking again twice and then nothing. No power to the gauges. Tore it back a part. Checked fuses and connections. All good. I put a volt meter on the ignition wires and get nothing from any of them. I am thinking a bad ignition switch. Would one of the relays near your left foot cause this? As always any wisdom is much appreciated.
Tore everything apart including the battery tray. Found the 40 amp green fuse lying on the bottom unplugged. I am sure I did not secure it properly when I put the new battery in. Still got clicking so I tested the starter relay and it tested ok. I tapped the starter with a hammer a few times a fired right up. Any ideas on how long before it totally craps out? I was hoping to get the rest of the season out of it.
