fxnytrose09
So I went out to start sled in my heated basement and it just cranked I could hear the fuel pump and smell gas. Year apart sled to check for spark found two broke flex pipes, junk. I've checked fuses and I'm reading on here about the relays, could that be my issue? How do I test them? Any other ideas? Thanks in advance for any help
fxnytrose09
I have no spark at the coils I should add
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Here you go.
herndonp
- Nov 28, 2012
- Freedom,NH
And this
fxnytrose09
fxnytrose09
I have power at the coils via the wires bit no spark at plugs any ideas?
fxnytrose09
I've checked everything. Crank sensor, relays, fuses, ecu, everything. Any ideas besides the diagrams
herndonp
- Nov 28, 2012
- Freedom,NH
You don't have your kill switch on do you?
fxnytrose09
No it doesn't crank over with the kill on, after checking all wires all of a sudden it's got spark so idk it's probably going to re occur. Thanks for everything guys
Yannie
- Jan 5, 2014
- Winnipeg
- 2010 Yamaha Nytro RTX
2 known wire harness rub points are, at the top of the steering post and behind the primary clutch along the frame. I had a issue where my main harness was running on this casting nub behind primary clutch.
fxnytrose09
- 8K
