LeeKo
Re: rattle
Makes sense. After installing the Drag n Flys, I started it on the sledlift...the track starting spinning at idle. That never happened with the stock weights.
sj said:Have the heelclicker 2 speeds and no rattle..its from the extra force the weights generate even at idle I believe..
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Normal for the 3 banger clutches to sound like a bag of marbles...
mytro
So can I ask this? Has anyone changed their clutching and had the rattling, vibrating and bag of marbles noise go away?
Mine gets noisier under power.....It's driving me nuts...............
Thanks...
Thanks...
ossjughead
I have the same problem on my 06 RS venture 4700 km it is so bad to listen too sounds like it is coming apart lol
Turk
Tech Advisor
Your engine is firing every second revolution. get used to it
yox185
This is the fix that Yamaha did to the clutches, they are on all the newer clutches. Unfortunately the o-ring that you see is the pic eventually becomes ineffective. You could replace it, and it really does help with the noise, but it's a pain in the buttocks to do. Taking the spider off the clutch requires special tools and sweat. My fix is to leave it alone and rev the engine, the noise goes away when I'm screaming in my helmet going down the trail.
