wolfe9904
- Dec 29, 2013
Does anyone know if there is a rebuild kit for a primary on a 2009 nytro?? My sled has 8100 miles on it and the primary is getting noisy .. Thanks everyone
No kit, you will have to buy the parts individually.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
Check my front end rebuild thread, I did my noisy primary and detailed w pics and SB kit and BOP parts.Does anyone know if there is a rebuild kit for a primary on a 2009 nytro?? My sled has 8100 miles on it and the primary is getting noisy .. Thanks everyone
There are spider shims available if you can squeeze them in. #8BW-17654-20-00
Use new 0-rings and the spider slide buttons that go over said 0-rings.
nor'easter
- Feb 12, 2008
- Pennsylvania
- Nytro RTX SE
You may want to check out Schmidt Brothers Motorsports for your clutch upgrades. They offer clutch kits, clutch rebuilding, primary overdrive machining, tuning kits, and quiet shim kits.
Hooray!
- Aug 12, 2017
- Maine USA
Interesting, wonder if these are the shims in the SB quiet clutch kit. As I have said before, I know everything is sourced somewhere, I appreciate when a small company supports our Nytro habit like SB and Moutaintech and BOP and RoczToyz and the list goes on... Thank you.There are spider shims available if you can squeeze them in. #8BW-17654-20-00
wolfe9904
- Dec 29, 2013
Thanks , I called chris at Schmidt brothers, I have all their other upgrades anyway and the clutch is on the way there as we speak ..You may want to check out Schmidt Brothers Motorsports for your clutch upgrades. They offer clutch kits, clutch rebuilding, primary overdrive machining, tuning kits, and quiet shim kits.
Hooray!
- Aug 12, 2017
- Maine USA
Chris is great, as noted, very happy w his quiet clutch kit and other SB adders on my sled.Thanks , I called chris at Schmidt brothers, I have all their other upgrades anyway and the clutch is on the way there as we speak ..
